shifting
Old Jul 31, 2007 | 02:32 PM
ZARRTX's Avatar
shifting
I just bought my first diesel, after many months reading here about them. You guys convinced me to buy a diesel. Nice ride. I bought a 2004 3500,dually 6 speed. 305hp. My question is, do you guys run all the gears, or do you do, 2-4-6? Also which engine oil do you guys use. Do you add Power Service to your diesl.
Please excuse the questions but I will be asking some more later.
I will not be pulling very heavy, this truck is for a slide in camper and pulling a jeep. Should I install those gauges for pressure etc.? Which do you guys recommend? Thanks for the reply. Zarr
Old Jul 31, 2007 | 06:45 PM
jkitterman's Avatar
starting in 2nd with no load and run all the gears.
Old Jul 31, 2007 | 06:54 PM
new2ctd's Avatar
Regular oil (called Dino)
Shell Rotella
Chevron Delo
Mobil Delvac
Valvoline Premium Blue
and others
Synthetics
AMSoil
Schaeffer
Royal Purple
and others
then each of the above regular ones come in synthetic forms also
Old Jul 31, 2007 | 07:23 PM
D-Roc's Avatar
Startoff in Second with no fuel most of time (unloaded), unless I need to get going in a hurry. Low for towing and tight spaces. I run through the gears allways and never skip ascending. Descending, I skip according to speed.
Chevron Delo 15W40
Chevron Synthetic 5W40
Schaeffer's 9000 5W40
I used PS, but prefer Lucas Upper Cylinder Lubricant Fuel Additive.
Old Jul 31, 2007 | 07:26 PM
Fire Rescue124's Avatar
i have a 04 2500 and i pull around 10 to 12K about every weekend and i will start in 2nd only if i'm on a hill will i use 1st. on level ground you need to be pulling alot to use 1st. i would always use 2,3,4,5,6 with or without a load. maybe if you are bombed out would i do 2,4,6 but as you can see i don't have anything yet i just know that without a smarty i am shifting every .5 sec. anyways so with a smarty i don't think i would be able to keep up with it.
Brendan
Oct 17, 2007 11:12 AM
98 Ram 24V
Dec 24, 2005 10:19 AM
lyvwire
Mar 20, 2003 07:45 AM
Jbolt001
Dec 1, 2002 01:31 PM
