serious problem!
Old Mar 8, 2008 | 01:45 PM
solostyle1's Avatar
serious problem!
I recently installed the sb66 turbo. Everything ran perfect. Lastnight, i installed the ddp 90hp injector nozzles and now there is a problem. I test drove it and it ran good but about 2 miles up the road the check engine light came on and lost all power. It almost sounds like its running on 1 cylinder but then it kicks back and runs good and then beack to crap. Any advice to what this could be? I pulled the codes and they are p2146, p0243.
Old Mar 8, 2008 | 02:33 PM
vzdude's Avatar
DTR's 'Go to Guy'
P0243 Wastegate Pressure Control PWM
P2146 Bank 1 (Cylinders 1-3) Shorted High Or Low
Sounds like a wire loose or rubbing inside the valve cover. Or a connection problem for the injectors.
Herrin811
Jan 2, 2006 12:23 PM
bdog
Apr 6, 2005 08:30 AM
Haulin_in_Dixie
Jan 7, 2005 04:28 PM
DZLPWR
15
Jun 3, 2004 04:46 PM
dsljunkie
20
Sep 13, 2003 01:54 AM
