serious smoke, rough running problem
Old Apr 2, 2005 | 08:25 AM
bdog's Avatar
Every day when I start my truck it blows a lot of white smoke and runs rough like I just changed the fuel filter or something. After warming up for several minutes or driving a mile or two it goes away and runs smooth, zero smoke, etc. Also occasionally it seems to lose power when driving. I can have it floored and the engine won't rev up and then all of a sudden it will just kick in and drive like normal. Temperatures are in the 60's when I am starting the truck so I don't think it has to do with the cold too much. Any ideas? I am not talking about a little smoke here either guys. If there is no wind it smokes so much I can't see the truck. If people are around they gather and point fingers etc.
Old Apr 2, 2005 | 11:37 AM
high country's Avatar
you better check the codes, turn the key from off to run 3x and look in the odo window, if you see po0216, if so you will be spending that tax return soon. it could be several things mostly minor from fuel filter, air filter, etc but it sounds like the death wiggles of the ip to me. check the codes and repost.....good luck
Old Apr 2, 2005 | 02:11 PM
bdog's Avatar
I just checked the codes. They are P0500, P0460, P1693. I sure hope it is not the VP. I have 157k and have already had two installed but they were under warranty.
Old Apr 2, 2005 | 08:12 PM
bdog's Avatar
Any idea on these codes? I lost the link to the page that tells what they are. If this is going to be a VP or other expensive fix I think I am going to trade the truck.
Not to get off topic but what do you consider an engine? I mean everyone raves about the cummins and how great and reliable it is and I agree when it comes to the block, pistons, rods, etc but what good does it do when the injection pump is junk? I have 157k and am looking at possibly the third injection pump. At $1000 a pop plus labor that is no small inconvience. I know three other dodge owners who have had problems with the VP and you would think that dodge would make good on it.
I was just reading the other day on the duramaxes and that they have problems with the injectors leaking. GM stepped up and gave at no cost a 7yr 200,000 mile warranty on these parts because they realized and admitted there was a problem. I still am leary of the dmax and want to keep my dodge but I cant aford to be putting in a VP every year.
Old Apr 2, 2005 | 08:18 PM
pind's Avatar
Bdog, man, I can understand what you are saying. I have been through 4 lift pumps, and now the IP is going out. It's still under the mileage and time warranty, and the dealer won't touch it.
Like yourself, I am a little leery of the DMax, but the dealer here backs the warranty really well. Talk about the rock and the hard place...
Old Apr 2, 2005 | 08:55 PM
MnTom's Avatar
Did you look here?? https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old Apr 2, 2005 | 09:18 PM
bdog's Avatar
Thanks for the link MnTom, it lists the P0500 but the others - 0460 and 1693 are not listed. Any idea what they are?
Old Apr 3, 2005 | 10:23 AM
MnTom's Avatar
Here is some useful info for you: http://www.dodgeram.org/tech/dsl/tro...urbo_diag.html
You can also look here: http://www.dieselpage.com/art0898tu.htm
If you go here you can put your info here and it will tell you what they mean: http://www.diagnosticdialog.com/LookupCode.asp
Tom
Old Apr 3, 2005 | 12:07 PM
po500 is no vehicle speed sensor signal, this should trigger the check eng light, po460 is no fuel level unit no change over miles.
you are in luck the speed sensor has to be cheaper then an ip! never bought one don't know.
hope that helps,
GREG
Old Apr 5, 2005 | 11:44 PM
AAmeeting's Avatar
Hey bdog, I was just reading another post about white smoke. I guess that the grid heater can go out not causing the air to be heated (obviously) and creating white smoke and alot of it. It is jus t like ford powerstrokes when glowplugs go out. Hope this helps.
Old Apr 6, 2005 | 08:30 AM
bdog's Avatar
Thanks for the replies guys. I gave up and traded her iin yesterday. I got a good trade in for 15k and I came home with a 02 Chevy with half the miles I had on my dodge. I hope it holds together for me.
nate_88
Dec 18, 2008 11:06 PM
Rays01
Jul 21, 2006 02:17 AM
Dan Brooks
Jan 10, 2005 04:26 PM
DZLPWR
15
Jun 3, 2004 04:46 PM
dsljunkie
20
Sep 13, 2003 01:54 AM
