Self Centering steering wheel
Old Feb 19, 2011 | 01:04 PM
silver_2000_tj's Avatar
Hey guys I'm hoping you can help me out or point me right direction, but the sterring wheel on my truck no longer self centers. No matter where I point the truck the wheel will not self center any idea's what that cound be?
The truck is a 2004.5 ram 2500 4X4
thanks
Old Feb 19, 2011 | 02:35 PM
15 Digger's Avatar
Maybe toe in or other alignment problem.
Old Feb 19, 2011 | 04:35 PM
I don't believe it's anything to do with the Toe in, is there any adjustments on the box? I can lock the steering all the way to the left or right and it will stay there until I pull the wheel back to the center. It’s really annoying going around corners or sharp curves in the road. And it can be a little scary going down the road having to make adjustments for the wind. You move the wheel a little to compensate and there is stays until you move it back.
Old Feb 19, 2011 | 06:00 PM
stiesel's Avatar
not sure i fully understand the problem. but i will not let that stop me from offering my opinion.
i'd say ball joints or tie rod ends.
jack her up and see how much play you have on the ball joints.
Old Feb 19, 2011 | 06:10 PM
15 Digger's Avatar
Could be steering box or other issue, ideas here are a start but good mechanic my help find the problem before throwing parts a labor at problem.
Old Feb 20, 2011 | 02:50 PM
megawhite's Avatar
i would say replace your steering box. my truck had some play in the steering from hitting a huge rock. after replacing front end i adjusted the steering box. it did the same thing your describing. it was a hassle to drive. replaced the box and much better.
Old Feb 21, 2011 | 11:17 AM
Bill M.'s Avatar
I would start with a good alignment shop. Have it checked for bent or worn parts and then do an alignment check. My 07 does a little better after I had it aligned.
Old Feb 21, 2011 | 06:31 PM
Lost Lake's Avatar
Caster. If the caster is off the wheel won't follow the pivot point.
Old Feb 22, 2011 | 10:29 AM
TedT's Avatar
Either not enough caster or to much friction. Most likely in ball joints.
Old Feb 22, 2011 | 08:34 PM
Lost Lake's Avatar
Exactly. Well said.
Old Mar 3, 2011 | 06:43 PM
Hey guys thanks for the information, I installed a new steering box and that solved the issue. Trucks running like a champ now!
qwest
Sep 29, 2008 08:14 AM
agalaczy
Jan 14, 2008 09:17 AM
Euronymous
Oct 15, 2007 06:21 AM
RonP
Dec 2, 2005 05:07 PM
MARKY MARK
Jul 6, 2003 10:26 PM
