screeching sound when jake brake is on.
Old Oct 17, 2012 | 01:32 PM
Housted's Avatar
Lately when the jake is on there is a loud screeching sound. It has gotten worse and the brake seems to be less effective. Any ideas?
2007 2500 4x4 5.9 CTD automatic trans
TIA Housted
Old Oct 17, 2012 | 07:02 PM
rebal's Avatar
you have an exhaust leak flip the brake on and pop the hood . it could ba as simple as a loose clamp
Old Dec 9, 2012 | 11:50 AM
Housted's Avatar
Talking Update
The exhaust manifold was shrunk lengthwise and sheared off the bolts on the first (front) port. Big leak causing the noise. Dodge refused to fix due to my Quadzilla Commander. They wanted $1400 to fix. I got the genuine Cummins parts from Geno's Garage. Total for all gaskets and new studs was $300. Also got really good advice from Scott there. Both broken bolts were easily removed due to small stub sticking out. All in all not too bad. I made my own extenders to support the heat shield and all is now good!!
Housted
Old Dec 9, 2012 | 01:52 PM
NickBeek's Avatar
Glad you got it figured out.
I would call Chrysler customer service and make a complaint that you were denied warranty over a set of gauges and see what comes of it. If you never had any chip or tuner on the truck, they should reimburse you for the parts....
ramseydiesel
Jan 5, 2010 06:31 PM
vwjunkie53
19
Dec 21, 2007 08:41 AM
Jim Dynomite
15
Jan 6, 2007 11:32 PM
spunbearing
Aug 27, 2006 10:36 PM
wap
Apr 24, 2006 07:23 PM
