School Me On Bosch Alternators
Old Dec 5, 2012 | 08:01 PM
06RAM2500's Avatar
So mine decided it was going to take a little longer to charge back to normal after the grids shut off. I took it off after it was decided the battery terminals weren't the problem. NAPA tested it and it failed the voltage test. I looked at the brushes, and they passed a visual inspection (didn't pull the cover off to look at the wires).
So is it still a chance the brushes are bad, or is it a little further into the alternator?
Old Dec 7, 2012 | 10:54 AM
Spooler's Avatar
What was the alternator putting out? It is controlled by the ECM. Make sure the cross-over postive wire from the passenger side battery to the drivers side battery is good. The ECM senses the load on the drivers side battery. If NAPA did the test properly, then the internal regulator may have a diode going out.
ramsport59
Dec 8, 2008 05:03 PM
Jim5870
Jul 15, 2006 01:32 AM
skeeter
Feb 3, 2005 04:39 PM
MCMLV
Dec 24, 2004 03:34 PM
MCMLV
Jan 15, 2004 10:59 PM
