Schaeffers 75-90w gear Oil ??
Old Jun 23, 2006 | 02:14 PM
coobie's Avatar
I am thinking about changing my amsoil gear lube in my diffs.out to schaeffers brand 75-90w.Any long time Schaeffers brand users here?If so how do you like there products?Thanks for any info.coobie
Old Jun 23, 2006 | 02:39 PM
routerguy99's Avatar
I think that schaffers coat the gears alittle bit better also I think that it runs cooler, You really should see the demo that any schaeffers can give you its pretty amzaing (Spelling )
Check this link out.
www.bobistheoilguy.com/images/lucas/lucas.htm
Old Jun 23, 2006 | 08:49 PM
C Schomer's Avatar
I'd like to hear about it, too. I'm getting into Schaeffer stuff bit by bit. So far the 7000 is good and I have a case of diesel additive ordered. My rep says they only make 75w90 gear. I realize that thicker isn't always better but RP 85w140 is the only lube I've tried that literally stopped the black gook buildup on the magnet in my Dana 80. Ams. 2k 75w90 was supposed to be miracle stuff but it sure didn't work for me. That's why I'm not sold on mere 75w90 for hard, hot use. Craig
Old Jun 24, 2006 | 12:08 AM
BothellDiesel's Avatar
I use schaeffers all around. X-200 in the engine and Neutra Plus 192 for fuel additive. The fuel additive is thick and has the highest % of aromatics on the market. Aromatics=Healthy pump seals. Also have schaeffers gear oil in the dif's but Redline in the tranny, MTL
Old Jun 24, 2006 | 07:57 AM
ckennedy's Avatar
schaeffers makes a 75 - 140 syn gear oil.. it may say 85 - 140.. but its 75 -140.. ask.. all you have to do is go to th site and look around..
Old Jun 24, 2006 | 02:26 PM
Oilguy's Avatar
I have used their products for about 3 years and have been extremely impressed with performance and test samples.
Oilguy
Old Jun 24, 2006 | 03:02 PM
abc4yew's Avatar
What's the easiest way to get shaeffer's oil products? ks
Old Jun 24, 2006 | 03:13 PM
coobie's Avatar
abcayew,I went to there website and went to there dealer locater site.coobie
Old Jun 24, 2006 | 03:38 PM
abc4yew's Avatar
Yep, tried that, Nothing for Ma, Me, NY, or Mi...the places I get to. KS
Old Jun 24, 2006 | 05:07 PM
coobie's Avatar
I live in southern Michigan.This guy is located in Northern Ohio,His name is Gene Shubert,PH# 419-658-2258.Give him a call maybe he can find someone close to you.coobie
Old Jun 24, 2006 | 10:21 PM
Red3quarter's Avatar
I don't use any of their oils in my truck yet, i will soon when i do a service at 75,000 miles. I do use their diesel addivite Soy Shield and it is a very good additive. Its better than PS or Howes in my opinion. But back to the oil thing, at my old job the fleet of semi's i worked on used schaeffers in all the diffs, trannys, engines, and the additive in their fuel. By switching the fleet to schaeffers synthetic oils all 22 trucks did notice a gain in MPG. Plus the oils all remained fairly clean when it came to the specified drain intervals. Plus a few of the trucks ran the synthetic oils long that some of the other truck had and they were showing less bearing failures in the hubs and axles. I think you'll be happy if you switch over to it.
matt
06er
13
Jan 30, 2009 08:51 AM
alaskanassassin
Jan 10, 2009 10:09 AM
k-oss
Apr 11, 2007 05:59 AM
snowmanx
14
Dec 11, 2006 02:35 AM
BulletMan
Mar 14, 2004 07:29 PM
