Safe trans temp limit?
Old Mar 25, 2008 | 05:49 PM
C Minus's Avatar
I tried searching but couldnt really find an answer.
What is the max trans temp safe limit?
Thanks all
Old Mar 25, 2008 | 08:00 PM
mmurray's Avatar
I had the same question a while back while towing through the mountains... I got up to 219 degrees... Nothing in the manuals... I know my banks PDA has an alarm set at 235 degrees... So I am guessing that would be max temp...
But I still haven't got an straight answer either... I spoke to a mechanic who told me at opperating temp your trans temp should be about the same as engine temp... within a few degrees... and as long as I stayed within that range I would be fine...
Agian, I'm still wondering what the real answer is too!
Old Mar 25, 2008 | 08:18 PM
rjm022's Avatar
tranny temp chart half way down the page
https://www.dieseltruckresource.com/...nny+temp+chart
Old Mar 25, 2008 | 09:50 PM
dozer12216's Avatar
The temp chart is goood place to look. ATF+4 is a high temp fluid with more durability than previous versions. Fluid will live at 250 degrees. As chart implies it starts to shorten as temps go above. Dozer rule of thumb: When fluid changes from reddish to more brownish, it was time to change before that happened.
Old Mar 26, 2008 | 02:15 AM
TexasCTD's Avatar
Here are a couple of different charts I saved regarding trans temps. Hope that helps.
ngkefalides
0
Aug 12, 2008 08:33 PM
offroadcpa
Mar 14, 2008 08:12 PM
coreydr2003
Feb 11, 2008 07:21 PM
avengermike
May 6, 2007 07:36 PM
Waldo4
Aug 4, 2003 07:36 PM
