Running Fuel Tank Low, damaging?
Old Oct 16, 2005 | 02:47 PM
PsRumors's Avatar
If I run my tank below 1/4 tank I get some rough running. It still idles well but a loss of some power and rough running is noticable. Is this damaging?
I assume it is air getting in. What are the fixes? Is the FASS the only fix for the Dodges? In the F%&d world this is a common problem.
Any advice?
Old Oct 16, 2005 | 02:56 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Bad idea, excess fuel is pumped thru the injection pump to help cool it. The more fuel in the tank the cooler the IP, I never let mine go below 1/4. Use a laser thermometer on the fuel tank sometime after you have been running awhile, it will surprise you the amount of heat transfered to the fuel, especially when your tank is low.
Old Oct 16, 2005 | 03:20 PM
PsRumors's Avatar
Is there a fix for this or am I just stuck with not letting it get below a 1/4? My build sheet says I have a 34 gallon tank but I have run 50 miles with the needle sitting on the empty pin and 0 mile DTE and was only able to put 28.2 gallons in the tank. It would be nice to feel comfortable running 500 miles to every tank.
Old Oct 16, 2005 | 07:48 PM
Dodgezilla's Avatar
Larry's right and you especially don't want to do it when it's really cold out or you have a better chance of the fuel gelling. Ask me how I know!! That injection pump is too expensive to burn it up so just keep at least 1/2 tank instead of 1/4 tank....
Old Oct 16, 2005 | 10:10 PM
PsRumors's Avatar
This really SUX!!! What good is a fuel tank if you can't use it. If I keep it at 1/2 tank or more I can only go 250 miles at a time. I drive from my home to Gainesville, FL quite often, it's a 400 mile trip and I like making it there without having to stop.
Old Oct 17, 2005 | 12:35 AM
HOUTEX's Avatar
DIDN'T WE HAVE BIG STRONG DIESEL TRUCKS IN WORLD WAR ONE & TWO ??
DID THEY BREAK DOWN IF THE FUEL LEVEL GOT TOO LOW ??
Old Oct 17, 2005 | 04:50 AM
bulabula's Avatar
In my experience, running low fuel in a tank is only a real concern if you have two or more fuel tanks where the empty ones could be left "dry" while operating the engine on the other(s). This pertains to gassers as well.
If there is only one tank, and the engine is running on it, there shouldn't be a concern. Running a tank low is factored into the design and engineering of it - a fact of life if you will.
Now if the tank is dry and the engine won't run due to no/incredibly low fuel (eg. no fuel to keep the pump cool) - turn the key off while you go find some more fuel and you won't burn the pump up. This ain't rocket science.
Old Oct 17, 2005 | 08:12 AM
SkyHarborCowboy's Avatar
Well I like to test my truck when I first get them to see how low is low on the Gauge. So far I have run the DTE to ZERO twice and happened to fill up right at Zero and 6 miles past Zero. Here are the results:
Zero DTE filled the fuel up to the top of the neck and got 37.8 Gallons into the tank!
6 Miles Past Zero DTE filled the fuel up to the top of the neck and got 38.3 gallons into the tank.
Now that I know what to expect I will fill up at 100 Mile DTE and use the last 100 as sort of a reserve.
Joe
Old Oct 17, 2005 | 10:45 AM
ASHNBAK's Avatar
I also have been to DTE 0 several times already. The most I ever got in that tank is 36 gallons. I go about 500 miles and fill it once a week.
Old Oct 17, 2005 | 10:55 AM
PsRumors's Avatar
By the numbers I can say with relative confidence I don't have a 34 gallon tank. Getting 28 gallons in a tank after 500 miles and on dead empty (but still able to run) gives it away.
What size tank was available other than the 34? I am assuming somewhere in the high 20s,
Old Oct 17, 2005 | 07:13 PM
hovisimo's Avatar
i have run my tank until it will take over 39 gallons to fill it up since i installed the vent kit, is there really evidence that this is a risk? i've gone over 700 miles on a tank, another one of the benefits of a real man's bed
Old Oct 17, 2005 | 08:33 PM
underwoodtransp's Avatar
you are all going to laugh at me but I have run mine 50 miles past zero dte. and I get 9mpg! I have put in 41 gallons and the truck was still running just fine. I put about 600 miles on a day and always run till it's empty then fill. If I filled at 1/4 tank all the time I would loose about half an hour each day. I can't afford that. I will be happy to see my titan supertank show its head in november so that I can have 60 gallons on board!!
Old Oct 18, 2005 | 12:24 AM
John Branom's Avatar
Vent Kit
What is a vent kit? please?
Old Oct 18, 2005 | 08:39 AM
Fat Asp's Avatar
John here you go http://www.dodgedieseldatabase.com/david_kelley.htm
Old Oct 18, 2005 | 02:25 PM
xyzer's Avatar
Any advice?
Could a failing lift pump cause this?......It will have more "lift" the lower the fuel in the tank gets......the "03" has the external lift pump. I can run mine to empty...or close to it and I have no operation issues.
