runnin rough limp mode??
Old Jun 24, 2010 | 10:09 AM
towpather's Avatar
my sig needs to be updated but got a new (to me) 06 it's bone stock except for a *****'s whistler and pyro and boost gauge. she started runnin rough on the way to work today and the cel came on. plugged in a buddys smarty and a p0107 (map sensor voltage to low) p0073 (air inlet temp voltage to high) and the mysterious p2149 (bank 2 cyl 4-6 shorted high or low) all came up. cleared all codes and restarted only the p2149 code reappeared. reset again and only a p0305 code present(cyl #5 misfire) again reset and restarted and only the p2149 was back.i drained the fuel bowl but made no difference. after a little searching i'm guessing a bad injector on #5 or a bad harness in the valve cover. shes been in under warrenty before my time for something related to #5 & 6 just cant remember what. i'll have to look when i get home. shes still under warrenty(57000) but i hate bringing it to the *********** for anything even when it's covered. any info and feedback will be greatly appreciated. gotta get her up and runnin and put back to work thanks
Old Jun 25, 2010 | 06:09 AM
towpather's Avatar
well after sitting all day yesterday it fired right up and drove home like normal last nite. looks like it might be a hit or miss problem.
Old Jun 25, 2010 | 09:58 PM
rich's Avatar
it is either the injector wire harness or you have an injector trying to short out
Old Jun 26, 2010 | 08:59 AM
BigDiesels's Avatar
I agree. mine acted up, then was fine for a month and finally let go. If you want to troubleshoot for yourself, pull the valve cover, disconnect each injector and check resistance. They should all be around 0.5 ohms. Sounds like #5 will be higher. Also, check continuity from the wire terminal to the pin in the plug receptacle.
tj97dodge
Jan 14, 2006 01:55 PM
swimmy
Dec 3, 2005 09:52 PM
OldSmokey
Mar 26, 2005 06:53 PM
arctic426
Feb 28, 2004 06:22 AM
danlit
14
Jan 20, 2003 06:55 AM
