RPM flux at start-up
Old Dec 19, 2009 | 10:15 AM
Dirk5.9's Avatar
My truck fluctuates RPM's about every 10-15 seconds after I first start it, the voltage gauge reads just under 14 and the lights surge, and then as I start to drive, it goes up to 14 until I turn it off and it does it all again.....any ideas? I've tried searching for this on DTR just can't find it
Old Dec 19, 2009 | 10:19 AM
06RAM2500's Avatar
Your grid heater is cycling. All normal.
Old Dec 19, 2009 | 10:28 AM
Dirk5.9's Avatar
Ok, thank you. I just noticed it so figured I'd ask.
Old Dec 19, 2009 | 11:14 AM
LeaperV12's Avatar
I stand to be corrected here but i think if the ambient air going in is lower than 32F or 0C, the grids will cycle until you break your crawl and pick some speed
Old Dec 19, 2009 | 12:14 PM
Dirk5.9's Avatar
It's 36F right now and it just now did it. I can't just let my truck roll, I have to pick up speed in order for the surge to quit if that helps any.....
Old Dec 19, 2009 | 01:48 PM
LeaperV12's Avatar
That's normal Dirk. Not sure what speed exactly but as soon as i shift to 3rd it'll stop, being in 2nd and around 1800 rpm, they continue.
It's just so that our combustion cycle is little cleaner rather than blow fuel out the exhaust because it isn't igniting at low temps
Old Dec 19, 2009 | 01:55 PM
15 Digger's Avatar
grid heater
my 06 will cycle well above freezing. I lasts about 120 seconds or until you reach 20 MPH.
bradler
Feb 18, 2009 12:43 PM
OldSmokey
19
Mar 26, 2008 05:11 PM
metal_miner
52
Jun 23, 2007 02:52 PM
O.T
May 30, 2007 08:55 PM
MoparRiggan
Jan 10, 2007 03:31 PM
