Royal Purpal in G56?
Old Oct 24, 2008 | 05:03 PM
Sniper05's Avatar
Hey guys is royal purpal Max ATF certified for the G56 tranny, it don't say it is on the bottle, but it don't say it ain't either, i was going to give it a try if it is! Thanks guys!
Chad
Old Oct 24, 2008 | 07:06 PM
spooled05's Avatar
ATF= automatic transmission fluid so no it wont work! Look in owners manual and it will give u oil and weight to use than find RP to use.Ive used RP in my dif's and love it,its a good fluid!
Zack
Old Oct 24, 2008 | 07:14 PM
Sniper05's Avatar
The G56 calls for ATF, or are you saying that maybe its not ATF+4?
Old Oct 24, 2008 | 07:22 PM
hivoltage's Avatar
It MUST be +4,not sure if the RP Max falls under that classification.
First time I learned of our manual tranny using ATF I didn't believe it.
Old Oct 24, 2008 | 08:07 PM
spooled05's Avatar
never herd of a manual trans using ATF,i could be wrong though?
Old Oct 24, 2008 | 08:10 PM
hivoltage's Avatar
Trust me the g56 uses ATF.
Old Oct 24, 2008 | 08:31 PM
Danderson's Avatar
Mopar ATF+4 is $4.42/qt. @ Walmart. I switched my factory fill out with Amsoil Universal ATF. Couldn't tell the difference.
Old Oct 25, 2008 | 08:36 AM
TedT's Avatar
I switched to the Royal Purple this summer, seems to shift smoother. But no it's not the recommended fluid. It has a slightly higher viscosity.
Ted
Old Oct 25, 2008 | 05:02 PM
Sniper05's Avatar
So i can use it then? If so i'm off to KOI to get me some!
Old Oct 25, 2008 | 05:03 PM
D-Roc's Avatar
I'm using the Royal Purple Synchromax...way smoother than ATF+4 for sure.
Old Oct 25, 2008 | 07:45 PM
Fisherguy's Avatar
Ted
I hope you know what you're doing, G56's aren't cheap...
Old Oct 25, 2008 | 08:30 PM
Sniper05's Avatar
Maybe i should ask what you guys recommend to change to? I have castrol full syntec in now, but smell ATF bad so i think it might be breakin down or? I want to change over to something better, what do you guys think i should run?
Old Oct 25, 2008 | 10:11 PM
mrblond's Avatar
I run Mobil 1 75-90 in a 4X4 PU with a Muncie Getrag, im suppose to run this special grey crap from GM.
I got 343K miles out of the first Xmission on the Mobil 1 75-90. The trans shifts really good and runs smooth but shifiing in reverse will clunk pretty bad unless I shift into first gear first then all is well.
The G56 is such a good quality and good shifting trans I wouldn't risk puting the wrong stuff in.
My plan is to extend the service life of the G56 by running Amsoil Mopar+4 and change it often. I haven't decided at what change interval yet but it will be ahead of the factory schedule and based on how much I pushed it.
Old Oct 26, 2008 | 12:55 AM
DREDnot's Avatar
I'm running Amsoil ATF in mine.
Noticed improved shift smoothness right away and after 10000 miles on it , so far, so good.
Old Oct 26, 2008 | 01:05 PM
XLR8R's Avatar
We run SynerGyn ATF in the G56.
