RokTech sensor = higher EGTs?
Old Nov 29, 2006 | 11:57 PM
XLR8R's Avatar
Just installed a RokTech on the '05 today at the shop; it seems as though the EGTs are higher when fueling, and get higher more quickly... would advancing the timing cause this, since the engine is more efficient now?
Old Nov 30, 2006 | 05:26 AM
AlCorr's Avatar
I have no idea but would like to know myself.
Old Nov 30, 2006 | 07:10 AM
MikeyB's Avatar
Should be the opposite, lower EGTs with more timing. At least mine did.
Make sure you rotate the sensor in the correct direction.
MikeyB
Old Nov 30, 2006 | 10:05 AM
XLR8R's Avatar
But it only goes in one direction (up)... and I advanced it all the way.
Old Nov 30, 2006 | 10:16 AM
MikeyB's Avatar
What's the before and after EGTs?
Mine dropped by about 100 degrees.
MikeyB
Old Nov 30, 2006 | 10:25 AM
XLR8R's Avatar
I only drove it 25 miles back from the shop so far, but it seemed like it would reach 1000 -1100 degrees more readily than before, with normal driving. I tried a couple of WOT runs and it didn't make a noticeable difference in EGTs - just seems like the gauge is more sensitive to throttle pressure now... maybe I was just hyper-sensitive - you know how it is when you've just tweaked your rig!
No way I'll be venturing out in this mess today for testing...
Tree DR
Mar 1, 2009 03:39 PM
RockcrawlingTJ
Nov 15, 2006 09:00 PM
one54ton
Jun 27, 2006 12:46 AM
jerry007
Oct 28, 2004 08:24 AM
