Ring gear replacement Ideas
Old Mar 31, 2016 | 09:57 PM
cminzey's Avatar
I have a 2004 4x4 dually with the 6spd trans I am thinking about changing the ratio to something a little taller than the 410 that is in it has anyone done this and if so what ring gear did you use ?
Old Apr 1, 2016 | 07:50 PM
BigIron70's Avatar
Cummins Guru
Remember you will need to do front and rear diff with same gear ratio. Ever think about putting taller tires on instead?
Old Apr 27, 2016 | 12:42 AM
junebug95628's Avatar
Off topic, I have the auto, 3.73 and 35" tires. I'm entertaining a trans swap to the 6speed. Do you tow heavy weight and why do you want to go higher ratio?
CD in NM
Mar 11, 2007 11:57 AM
98.5POS
37
Jan 26, 2007 08:26 AM
HaulinBut
May 12, 2006 03:06 PM
midwestdually
Jan 7, 2006 03:15 PM
StrokeThis2500
Dec 31, 2005 05:19 PM
