Regearing the rearend
Old Aug 4, 2010 | 01:52 PM
Bob 1's Avatar
I think someone on here said if you regear to 3.42 from 3.73 (stick or auto?) you should pick up MPG. Anyone know for sure? Is it worth the cost?
Old Aug 4, 2010 | 03:05 PM
nvr-enuf's Avatar
I believe cost is about $1200 if you replace both ring and pinions as well as the rear end bearings,seals, rear end oil, etc. Labor is probably $500 to $700 which would cover both.
About a 1.5 to 2.5MPG increase. I thought about it and instead I went with the 285 / 75 / 17 dura grappler tires which helped my mpg. They are the skinest tires in the 285 series - I know that does not make much sence since 285 is the width but they are significantly narrower than 285 BFGs.
Search 3:42 and you will find LOTS of info
Old Aug 4, 2010 | 03:53 PM
1-2-3's Avatar
Just a plain ole guy
I wouldn't do it. It would take at least 5 plus years to just break even, and depending on how many miles you drive. Just maintain your truck and drive it economically.
EdmontonCanada
0
Oct 2, 2014 07:34 PM
Harley Davis
Oct 18, 2007 01:39 PM
John Rodriguez
31
Apr 14, 2005 12:05 AM
John Rodriguez
Mar 3, 2005 09:40 AM
