reflash results
Old Jun 20, 2006 | 02:43 PM
supersonictoys's Avatar
reflash results
had my truck flashed last week ,overhead imediately read 3mpg better . I completely topped off the tank to where it ran out on thr ground and wouldnt take anymore. drove it 250 miles round trip and filled again at the same station and even at the same pump untill it wouldnt take another drop. over I got the same exact mileage as before. only thing the flash changed was that it screwed up my overhead reading was a total waste of time. I think everyones mileage varies because everyones driving technic is different
Old Jun 20, 2006 | 03:12 PM
HappyGA's Avatar
In your sig it says that you completely ported your intake pipe. Now I heard that the white fins that are in the turns need to be left. They supposedly help the air turn the 90* bend easier.
Did you remove these as well???
Old Jun 20, 2006 | 04:36 PM
goose2's Avatar
I agree with you on this one. The reflash did nothing for me at all. I just keep driving it and hoping someday it will get 30 mpg.
Old Jun 20, 2006 | 07:02 PM
nope ,didnt remove the white plastic stuff, just took the plastic tube center portion and removed the cross pieces in the center and then also removed all the silencer rings from the tube itself . now its just like a big piece of pvc pipe except it still looks factory from the outside.
Old Jun 21, 2006 | 11:20 AM
bigblock2stroke's Avatar
The overhead calculation is designed to correlate to hand calculations:
1. Only on the first shutoff. If you fill it until it comes out of the filler tube, it will never match.
2. You have to reset the overhead every time you fill up.
Old Jun 21, 2006 | 11:23 AM
where did you read that about the first shut off? is it in the owners manual?
mr. ed
May 6, 2009 07:20 PM
03quadduallyho
32
Apr 18, 2004 03:19 AM
Hummin Cummins
31
Mar 20, 2003 07:16 PM
TPilaske
Feb 16, 2003 11:17 AM
KatDiesel
25
Feb 7, 2003 10:45 PM
