rear main seal change
I was driving through vegas yesterday and looked under my truck, I had oil all over everything under the engine. It looks like its leaking between the engine and tranny I was wondering how hard it is to change the seal and what special tools are needed?
Its leaking a quart every hundred miles so it has to be fixed. I also noticed every now and then the pyro gauge would start going crazy, I would shut the truck down and everything would be fine. Im thinking there might be an injector sticking too. I could not smell diesel in the oil but I thought it was higher on the dipstick. any advice would be helpfull I have to have it running by the end of the week.
Not sure about your injector issue but when I replaced my clutch I too noticed a significant amount of oil dripping from the bellhousing. I went to the local Freightliner dealership to order my rear main seal (WAYYYY cheaper than Dodge) and they told me to replace the o-ring on the back of the cam. Pulled the tranny and come to find out the rear main was hardly leaking at all. That little 0-ring was the cause of the leak. Had everything tore apart so went ahead and replace the rear main too, better safe than sorry. Good luck.
ted_pulliam
Aug 4, 2010 11:33 AM
