rear end going out?
Old Jun 7, 2007 | 08:07 PM
mooseman's Avatar
rear end going out?
Lately under moderate acceleration I can feel a grinding vibration. Today it started a vibration at highway speeds.
Tonight I pulled the plug on the rear differential , oil puked out like it was way overfull and it looks like a thick silver paint.
I could be wrong but I think my rear is going out with only 5500 miles on the odo.
What do you all think.
Mooseman
Old Jun 7, 2007 | 08:29 PM
jamesbfishin's Avatar
"silver paint" ? is it cloudy, that could mean that water got in there, might want to check the condition of the vent hose. I'm sure others here that are more knowledgable than myself can help
Old Jun 7, 2007 | 08:40 PM
mooseman's Avatar
Its not at all cloudy. Just looks like thick silver paint.
mooseman
Old Jun 8, 2007 | 02:59 AM
TexasCTD's Avatar
It may have been overfilled from the factory. I'd just change it out and put in a good GL-5 rated synthetic gear oil and see what it does.
Mine had a silver paint look to it too. These AAM Axles start life with very very tight tolerances. I have heard (from a guy on here who knows a guy who works for AAM)....that these axles will get up to like 650 degrees during break-in. Once broke in...they will run great. Just dump that old fluid and put in some new.
Personally, I use Mobil 1 75w90. But there are plenty of good brands out there.
Old Jun 8, 2007 | 07:32 AM
vzdude's Avatar
DTR's 'Go to Guy'
A lot of that silver is also the gear marking compound used when setting up the axle.
Old Jun 8, 2007 | 08:03 PM
mooseman's Avatar
The dealer says everything is fine and blame any vibrations on my new tires.
It only vibrates under HEAVY acceleration and it started a week before I installed the tires so I think that rules the tires out. They also said everything in the drivetrain including silver oil is also within spec.
OH WELL ill runer till she blows and then fix whatever breaks.
Mooseman
1999blackcloud
Jan 26, 2010 08:52 AM
DIESELWRKS
Jul 29, 2009 06:06 PM
doorguy
Jun 8, 2007 06:19 AM
Turbo Deeezle
Apr 11, 2006 10:48 PM
royta
Jul 13, 2004 06:54 PM
