Rear Driveshaft U-joints
Old Jun 17, 2008 | 10:02 PM
bluechrome's Avatar
I ordered Spicer 1480 U-joints. I just wanted to make sure there the correct ones. Any heads up on pressing them in and torching the old ones out? My original ones are Dust
Old Jun 17, 2008 | 11:29 PM
DodgeCowboy's Avatar
DTR's Cow Boss
Simple trick if you don't have a press you can use a vise. get a socket that will go though the opening too press the cap out. On the reverse side use a socket thats way bigger too catch the cap on the side that is being pushed out. Soak them in some good penetrating oil keep a socket and a ball pean hammer to tap the cap if need be. Ummmmmmmmm also press the new caps in don't hammer them you will stand a worse chance at causing the needles too tip over and give you grief and allot of cussing headaches and make sure you have grease in the caps too hold the bearings in place.
Grit Dog
Oct 18, 2013 01:22 AM
NoSparkplugs
May 1, 2012 12:55 PM
goosepilot
Apr 29, 2009 12:00 AM
Hummin Cummins
Aug 19, 2004 04:35 AM
