rattle at bellhousing
Old Feb 22, 2013 | 08:02 PM
jp127761's Avatar
I have a rattle that is worse in park or neutral that is coming from bell housing area, I took inspection plate off and its louder. I didn't know if maybe had cracked flex plate?
Old Feb 22, 2013 | 08:27 PM
BigIron70's Avatar
Cummins Guru
Flex plates have been known to crack, If it quiets down in gear then most likely flex plate. Also check crankshaft end play, worn out thrust bearing will allow crankshaft to walk back and forth, allowing torque converter bolts to hit housing.
glennh220
Jan 19, 2005 09:36 AM
moparguy
Nov 1, 2004 04:08 PM
Palmetto_kid
26
Apr 16, 2004 09:02 AM
Commatoze
Mar 17, 2004 08:35 PM
