Ran out of fuel? Not Really!
Old May 3, 2010 | 08:44 AM
Rglover's Avatar
2006 Dodge Ram 2500 Mega Cab 5.9l
Yesterday I was just below 1/8 tank. The lo fuel light was not on and the truck quit. I had experienced this once before on a trip and was able to coast to a fuel pump and fill it up, watch in the filter housing until it was full and it started right back up. I have been told that my fuel sock inside the tank is probably gummed up. Does this sound right? Yesterday I had to add 10 gallons of fuel before it would pump to fill the filter housing. I then went and filled her up and it took 15 gallons, telling me that I still had 10 when it quit.
My questions are:
1) Is the sock filter in the tank cleanable/replaceable?
2) Could it be the lift pump starting to fail and not the sock filter?
3) Should I just go ahead and replace the lift pump while I am in the tank?
4) Is there a fuel additive I should try to clean the sock filter prior to dropping the tank?
The computer is not handing out any codes at all.
Any other suggestions/ideas will be greatly appreciated.
Thanks,
Robby
Old May 3, 2010 | 12:24 PM
davidj54's Avatar
Has it done it at the same level both times?
If it indicated 1/8th and you had 10 gallons left your sending unit is way off. I'd be inclined to drop the tank and find out what's going on.
jefe4x4
25
Dec 15, 2011 07:33 AM
sqrl$$
May 21, 2011 11:15 AM
Deadbunny
Mar 29, 2009 10:17 PM
Buckshotmckee
Jun 10, 2005 12:23 PM
