Knock and missing under acceleration
2003 Cummins start and idols fine has a knock / miss under acceleration it comes and goes.
several codes
p0633
p0483
p0480
p0192
the fan clutch wiring in cut I’m replacing it.
The engine oil level may be rising?
not sure someone else added oil when it was low then it was overfilled
several codes
p0633
p0483
p0480
p0192
several codes
p0633
p0483
p0480
p0192
several codes
p0633
p0483
p0480
p0192
As for the P0633, I had that forever. Never figured it out and never found what it affected, if anything.
Back to morning brew . . .
Update new injectors installed correctly, still has low rail pressure.
truck will initially fire up an idol fine when you give it throttle, it will go into fuel knock as if the FCA has been unplugged and then with low fuel rail pressure code will come on.
TxDiesel007
06-19-2012 07:31 AM
cincydiesel
08-24-2011 09:46 PM
