Radiator took a dump....
Old Dec 26, 2008 | 10:34 AM
Ram Daddy's Avatar
Angry Radiator took a dump....
Well ....as we were getting ready to take a trip up to our property in Gainesville , I notice I`m missing one of the caps on the trailer , (loaded up with our Trans Mule , daughters new 4 wheeler , and all our gear) so I move the truck out of the way , as it`s already hooked up and ready to go , and notice a HUGE puddle of fluid where the truck was just sitting
Needless to say , it`s the radiator , and no one is open on Christmas day ,or today, so I guess we`re staying home this weekend
Just wondering if anyone else has had a problem with the cooling system , or is this truck just bad luck for me
We were planning on leaving after Christams dinner @ my moms (around7PM) , and it`s a good 3 hr. trip , so I guess I`m LUCKY I moved the truck when I did , and noticed the leak BEFORE we hit the road at night
as this would have been the 3RD time we would have been broke down in this truck , either on our way to , coming home from , or at Gainesville...and man , would the wife had been pissed....she`s already no TOO happy.
Old Dec 26, 2008 | 11:23 AM
MikeyB's Avatar
Sure it's the radiator and not the crappy clamp on one of the hoses?
The radiator seems to be pretty reliable on these trucks.
MikeyB
Old Dec 26, 2008 | 11:25 AM
John Faughn's Avatar
The header line in your thread says its the rad , but then nothing in your description tells where the leak is from .
If your lucky , maybe the overflow tank was full , were you parked on a angle , tilt , hill - then coolant came out of overflow .
Use a pressure tester and see where the coolant is coming out .
Is the rad cap on tight ?
Any work on the truck recently , maybe a lose hose clamp ?
Old Dec 26, 2008 | 01:06 PM
surfram's Avatar
Have you checked the water pump? They can spray anti-freeze all around the passenger side front of the engine when they start leaking. It is a very easy repair if you can get the pump.
Old Dec 26, 2008 | 06:10 PM
Ram Daddy's Avatar
Question
It`s leaking from the middle part of the radiator.....maybe it`s the water pump , but it`s definately running off of the radiator.
Old Dec 29, 2008 | 03:31 PM
Ram Daddy's Avatar
Exclamation
Well...it was the radiator , had a hole in it.
It must have been a fluke thing if no one else has had an issue. Glad it happened when it did , and not on the way
johnny5.9
May 7, 2015 10:43 PM
capt.Ron
Feb 25, 2014 07:52 PM
Mark Thomas
Jun 17, 2005 05:50 PM
Turbo Deeezle
Jun 4, 2005 08:49 PM
Tommy93w350
Jan 11, 2005 08:22 PM
