Question for Quad re: Commander boost tap
Old Apr 18, 2007 | 10:37 AM
ptgarcia's Avatar
Quad,
I'm getting funny boost readings on occasion and think its probably caused by the tap on the boost sensor. No running issues with the truck just funny readings. While accelerating, it will linger on 0 psi boost, then immediately jump up to 15 psi or so, then bounce around erratically and so fast you can't tell what its saying. Other times it reads perfectly. I assume the wire tap isn't making the best connection which leads to my question:
Can I pull back some of the insulation on the module harness and solder a short pigtail to it without screwing up module operation?
Thanks!
Old Apr 18, 2007 | 11:26 AM
ptgarcia's Avatar
Dang it! I put this in the wrong place! Can a moderator move it to the 3rd Gen Performance section?
LovinTheTorque
Sep 14, 2013 12:02 PM
glarior
May 17, 2011 07:46 PM
fade94
Sep 16, 2008 11:50 AM
ptgarcia
Apr 19, 2007 01:34 PM
Hoss
Apr 11, 2006 11:37 PM
