Purple Turbo, Normal? Heavy towing
Old Jul 30, 2009 | 10:51 PM
popeyesides's Avatar
Originally Posted by RiverRat2
These engines are made to work hard,,, if you do alot of empty easy running some actually begin to idle a little rough,,, after a good heavy loaded work out,, it seems to make them smooth out....
I use my dually only to haul my toyhauler thats why it has low milage, My friends ask what I have done to the motor to make it run so smooth, I always tell them I use it for what it was built for.
Old Jul 31, 2009 | 12:00 PM
RiverRat2's Avatar
Yep!!!! I very seldom use mine unless it's hooked up or I need to haul something in the bed,,,,, Otherwise I drive my Yota 4 banger @ 37MPG Thank You very much!!!!!!! LOLOL!!!!!
Old Jul 31, 2009 | 01:48 PM
Posted new pics.
Old Jul 31, 2009 | 02:57 PM
RowJ's Avatar
Posted where??
The members that have egt probes before AND after the turbo say with a heavy load the difference can be closer to 500*!
Cummins said 1150* post turbo is approved?? I know 3rd gens handle heat better than 2nd gens but that still sounds very hot.
I'd be thankful if only the turbo is showing a heat signature!
I've seen them turn gold or amber! Purple must be the next level up.
RJ
Old Jul 31, 2009 | 03:58 PM
03 ant a hemi's Avatar
I had a pre and post pyros. My numbers were around 150deg cels or less if I recall. Not enough for me to worry about.
But what I did notice was pre turbo would cool off much quicker the post turbo. I found shut down temps were hotter in the elbow then they were in the manifold. Which I found kinda odd. If your using your pyro for shut down temps then post would be my choice.
Old Jul 31, 2009 | 07:52 PM
Originally Posted by RowJ
Posted where??
Cummins said 1150* post turbo is approved?? I know 3rd gens handle heat better than 2nd gens but that still sound very hot.
RJ
That's right, The Cummins engineer of 30 years gave me this info, His name is Mike Kell and number is 800-343-7357. He said he could not tell me what the max egt is for our trucks but did say I could run 1150 degrees all day long and that was post turbo were he said the probe should be. He said the probe gets way too hot in the manifold pre turbo and has seen many probes fail because of too much heat and break off and take out a turbo. He explained why with his engineering talk that I didn't understand. I put my pics on my firt post. I'll check and make sure they are their.
Old Jul 31, 2009 | 08:41 PM
ripping r's Avatar
your turbo looks just like mine. i'll get some pic's tomarrow.
Old Jul 31, 2009 | 10:17 PM
Thanks, My friend brought his 07 5.9 over and his looks the same, he tows a 34' toyhauler w/ his Jeep in it as well. So no worries on this end.
Old Jul 31, 2009 | 10:43 PM
ripping r's Avatar
good to hear.I have lots of warranty so i never worry.
Old Aug 1, 2009 | 06:09 AM
bnold's Avatar
Those pics are crazy! Think what you wish... Maybe your cummins engineer will rebuild your motor on the cheap, but that dude is HOT!
I've ran 1200-1250 for hours on end hauling equipment or hay PRE-turbo and mine look brand new... I'd poo a brick if I saw my turbos looking like that
Old Aug 1, 2009 | 08:57 AM
carl48's Avatar
the 04.5 up trucks use a in cylinder egr scheme for epa emissions. in the way it works it gives a higher pyrometer reading than pre 04.5 and 1600* gives about the same piston temp as 1200* on pre 04.5 in fact it is a little cooler.
Old Aug 1, 2009 | 09:03 AM
AH64ID's Avatar
Just got back from Utah towing my 42' toyhauler with a Jeep Unlimited in the back, approx.20klbs for 2500mi. and noticed my turbo is kinda purple in color, Yes I have gauges and ran 1150 degrees max on pyro, post turbo in jake brake per Cummins, Cummins told me I can run 1150 Post turbo all day with no worries. I have 25k miles on the truck. Is this normal for the heavy towing guys?
1150 translates to about 1450ish pre, which is what has been said is the max continous for the HPCR.. so that's okay, BUT, what setting was your smarty on?
That color change is pretty common on the HPCR, for stock timing.
Cummins has always been anti pre-turbo pyro.. but when was the last time you saw or even read about one failing? I will always run pre-turbo because its more accurate.
You have a 2nd gen, EGT's cannot be compared 2nd gen to 3rd gen.
Old Aug 1, 2009 | 10:42 AM
bnold's Avatar
Understand 3rd gens run higher temps, but of all the trucks I've been around that pull big loads on a daily basis (read: hotshot) no truck post 04.5 have I ever seen a turbo that discolored...
Old Aug 1, 2009 | 11:08 AM
AH64ID's Avatar
Yeah that one is pretty discolored... Makes me curious how the Smarty jr was setup.
Old Aug 1, 2009 | 03:42 PM
White Ghost's Avatar
the rurbo on my 04.5 looks the same. i got 353k on her before i dropped a valveseat. now i am looking for another motor or i am going to rebuild. i don't know which i am going to do.by the way i do hotshot heavy loads with a 40' float.
