Problems after installing new lift pump
Old Oct 26, 2009 | 05:50 PM
RHC's Avatar
RHC
After installing new OEM Lift Pump, cranked it up ran fine checked for leaks today as it was running. it was leaking so i tried to push the quick connect togather more and it really started leaking bad. before i could get out from under the truck, it shut down, no fuel pressure. I got back under the truck and took the quick connect apart (disconnected the line). and look at the seal inside the line. It looked ok. reseated the connection and no leaks now, drove it down the road got on it runs good.
The only problem now it takes a few seconds longer to crank. i mean a noticable differance in how long it takes to crank. NO Smoke either. Could there be air in the fuel system?
Did i do something wrong?
Old Oct 26, 2009 | 06:33 PM
rich's Avatar
could be getting air thru the quick connect, mite want to get some new ones and replace the old one. never liked them things seems they only are good for one time if their old
Old Oct 26, 2009 | 08:46 PM
msawdust's Avatar
When I replaced my fuel pump with a original canister mounted pump I could not get the quick connect fitting off so I left it on and reused it. How do you get it off? I would like to put the new one on that came with the pump.
Old Oct 27, 2009 | 06:52 PM
RHC's Avatar
RHC
i just squeezed the blue clips togather and pulled the line apart.
redneckdieselpower
Feb 26, 2015 11:06 PM
mrjdm01
Mar 22, 2009 09:03 AM
DNRCustoms
Jan 21, 2009 07:22 AM
garybg1
17
Apr 10, 2007 01:07 PM
lightening ram
28
Dec 29, 2005 10:19 PM
