powersteering box problems, anybody replace theres yet???
Old Mar 18, 2006 | 01:03 AM
ocsurf16's Avatar
Dealer told me today that i have a leak in the power steering box and thats why my wheel is shakey in slow driving turns...they want 600 to put a new one in..truck it out of warranty cause of my 65000 miles...has anybody have problems with there power steering yet?? and if so how much involved is doin the job myself??
Old Mar 18, 2006 | 08:46 AM
RockRover's Avatar
I haven't done the job YET, but looking at it, the Dodge seems like a straight forward R&R. Biggest issue (in every box I've replaced) hase been removing the pitman arm from the sector shaft...some are easy, some not.
Not trying to hyjack here, but I'm having increasing difficulty turing my wheel in parking lot's w/o any forward movement. When she's cold, I can forget turning. Me thinks it's the pump, but it is not RPM related? Hmmmmm.
--D
Old Mar 18, 2006 | 08:50 AM
HdPower's Avatar
Yup, mine leaked and was replaced by the Dealer under warranty...seems to be a few people that have this problem.
Old Mar 18, 2006 | 09:04 AM
ocsurf16's Avatar
only comverd under the 3 year 36,000 though it blows
Old Mar 20, 2006 | 10:51 AM
GEN_X's Avatar
Has anyone produced a new aftermarket one yet. That may be a little longer lasting
Old Mar 20, 2006 | 11:00 AM
Dodgezilla's Avatar
I noticed that mine's leaking now too. No other issues with it yet though. I haven't even seen a drop of fluid on the ground yet. Just some on the casing. I guess I'll wait till it goes altogether.....
Old Mar 20, 2006 | 12:38 PM
narlinghaus's Avatar
Haven't looked into it completely just yet, but PSC (Power Steering Components) supposedly makes a replacement kit. I haven't looked into it, I have only been told about it from a couple friends. It is supposed to include a brace of some sort also. Their website is www.pscmotorsports.com but they don't list it on there yet is what they told me.
The owner/founder of the company was the "A" of AGR steering. So he has been around for quite some time.
Old Mar 20, 2006 | 01:09 PM
BigBlue's Avatar
I'm running a PSC and so far I like it. You can one finger the steering wheel at low speeds. They are pretty easy to install. The hardest part is getting the hydraulic lines to line up perfectly so they'll thread in straight.
Old Mar 20, 2006 | 03:04 PM
Mexstan's Avatar
Mine was replaced by the dealer at my first service. They told me that it was a factory defect. Reason it was changed was because the steering was stiff. Had the front end aligned at that time. Been great ever since.
Old Mar 20, 2006 | 05:49 PM
SOhappy's Avatar
Mine leaks at 31,000 miles. I've mentioned on this forum before that pressure seems to build up in the resivor, causing the leak. When you take the cap/dipstick off does is go "pssssst"? Somebody on here said to install one with a vent hole and that solves the leaking problem.
More to the point though, why on earth would a leak cause faulty steering (unless all the fluid leaked out)? You should be just fine keeping it topped off.
Old Mar 24, 2006 | 10:32 PM
Ramguy 05CTD's Avatar
Had mine replaced at 3k . Was leaking like crazy. Fluid in resevoir was at the bottom of the dipstick. Now loosing drivability again
Old Mar 24, 2006 | 11:58 PM
Scotty's Avatar
Top's Younger Twin
Had mine done shortly after I got it and its now leaking again. Not bad but it is wet.
Hurry up Mega Cab long bed availability!
noname91
Feb 11, 2010 02:58 PM
Billm2004
Sep 11, 2007 03:50 PM
1trick4u
15
Jan 8, 2006 01:48 PM
bhoeffner
Dec 22, 2005 08:56 AM
