Power Take-Off (PTO)
Old Nov 21, 2004 | 04:50 AM
Steve-l's Avatar
Question Power Take-Off (PTO)
The '04 6 speed (NV5600?) has square covers that bolt on both the right and left side of the case. I assume these are mounting points for a PTO. Do any of you know if this is correct? If it is, are they available through Dodge or the original manufacturer? As a by the way, who does make this gearbox?
Old Nov 21, 2004 | 07:12 AM
Hounddog's Avatar
Its built by NEW VENTURE.I've seen tow trucks and of course they have the pto operational.
Old Nov 21, 2004 | 03:51 PM
Nevada's Avatar
The PTO mount covers are six bolt, vertically oriented rectangles, almost square. Sounds like what you are looking at. The bottom bolt holes are also used as a drain if you want to change your fluid. If you take off the covers there is a small square flat magnet on the bottom of the transmission that can be removed for cleaning.
As Hounddog indicated it is a New Venture model NV-5600. Any 6 bolt style PTO accessory should work just fine.
4969joes
Mar 28, 2010 05:26 PM
andy9874
13
Mar 20, 2009 05:23 PM
B.Law
Aug 27, 2005 12:46 PM
Dave88LX
14
Aug 23, 2005 02:08 AM
yarddog
Aug 2, 2005 10:57 PM
