Power Loss
Old Nov 7, 2005 | 07:14 PM
05ctd3500's Avatar
Power Loss
I've had this truck for 6 months and almost 10,000 miles. The past 2 months, the power has gone down . I've heard that the power is going to increase, not decrease over time.
Any ideas?
Old Nov 7, 2005 | 07:16 PM
jay05torque's Avatar
fuel filter....1st guess, air filter 2nd
Old Nov 7, 2005 | 07:28 PM
05ctd3500's Avatar
Tried both. No improvement.
Old Nov 7, 2005 | 07:37 PM
bad fuel, try a different location...otherwise consult the higher powers on here. i'm a minnow in the ocean buddy...best of luck
Old Nov 8, 2005 | 08:57 AM
dodgestang's Avatar
Broken intercooler causing a boost pressure drop resulting in lower than expected performance?
Do you have any blowing type noises when accelerating or holding RPM over 2k?
Old Nov 8, 2005 | 09:45 AM
John Halter's Avatar
From: somewhere in northwestern ohio....Mansfield, Oh
Has fuel mileage gone down with power ? Could be a bad injector our just winter fuel .
Old Nov 10, 2005 | 08:04 PM
05ctd3500's Avatar
No noises from engine area....decrease 3-4 mpg...........
Old Nov 10, 2005 | 08:31 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Welcome to the joys of Winter blend fuel..it happens every year starting some time in October and lasts until Spring.
Old Nov 10, 2005 | 08:45 PM
05ctd3500's Avatar
Started early Sept.
Old Nov 10, 2005 | 09:10 PM
trik396's Avatar
Do you have any guages? What do your boost numbers look like. How is your oil level? Do you run any additives in your fuel? If not, maybe fouled injectors. Just a few thoughts....
Old Nov 11, 2005 | 07:30 AM
Sevir's Avatar
most likely you arent loosing power, you are just getting use to the power. I thought the same thing, pull up next to a ricer from time to time and give him something to breath in.
Old Nov 11, 2005 | 08:33 AM
dodgestang's Avatar
Yeah, there is only one problem with that though....they don't know when to quit. You leave in the smoke, run it up fast and hit that old 3200 RPM wall and are tapped out at 107 MPH (at least I am). Then they slowly eek by with their 108 MPH top speed after 60 seconds....and think they won.
Old Nov 11, 2005 | 11:50 AM
Sevir's Avatar
Lol, i dont think i can go 107 off a red light, usually you are in city areas. most of the time i just hit 45 or 50 let off the go pedal as they zoom buy thinking they are winning but knowing they just got smoked.
RHC
Aug 12, 2019 03:32 PM
tntk9
Nov 20, 2012 07:09 PM
cbrxxtreme
24
Jul 17, 2008 03:30 PM
Ranger 2/75
Mar 16, 2006 05:07 PM
jdcott1
Oct 20, 2002 11:48 PM
