Possible fuel pump issue?
Ok heres the issue: driving on hiway or city whenever i take my foot off the fuel pedal the truck will drop to 0 rpms and stalls.
Ive called dodge and cummins both say it sounds like a failed fuel pump but its one of the relocated ones in the fuel tank and ive heard those are supposed to last a long time.
Truck is 03 2500 5.9 quad cab short box.
Looking for a 2nd opinion on this, thanks
Yeah, that could be a pump. Turn the key on, listen to the pump, see if it runs smoothly.
Do you have any codes? Used the key method. If you get a 0234, it's probably the pump. (I think that's the lift pump code.)
A tube that is used to suck the fuel up......... the problem with that, like i have, is the 1/4 tank issue. I have to keep the fuel level up or the pump starts to suck air when the fuel sloshes back and forth
Cummins Guru
P0251 could be a bad fca do you have a fuel knock black smoke or engine runs rought at idle? Fuel pressure fluctuates at idle more then 500psi or fuel pressure higher at idle then 2500 rpm.
P0234 is over boost code, is truck stock? Could have stuck waste gate or bad map sensor.
Cummins Guru
You have No lack of power and engine will idle OK. This will be difficult to diag unless you can monitor the fuel pressure and boost pressure. Clearing the codes and seeing which code goes active when driving. You can check fuel volumn from lift pump and CP3 pump but checking limit valve and CP3 pressure requires a scanner and some special fuel system test adaptors.
Read TSB which will give you some idea of what will need to be tested.
ddestruel
Apr 5, 2014 10:40 PM
hoot
Nov 23, 2004 10:28 PM
barracuda
Nov 14, 2003 01:42 AM
