Possible Bad Injector or what??
Old May 1, 2012 | 08:40 PM
JJPage's Avatar
Re-torque your cross tubes, 39 ft lbs. If you have a 24mm and a 19mm crowsfoot for your torque wrench it will make the procedure easier. If your tubes are loose, you lose rail pressure, hence the long crank times, also could be causing the idle issues.
Remove the intake horn and injector lines for access, not too bad a job, about 2 hrs start to finish.
Old May 1, 2012 | 10:44 PM
RAMMINVA's Avatar
I guess I need to get this thing hooked to a good computer as a next step, a friend of mine has a very new updated Snap-On one.
Old May 2, 2012 | 02:04 PM
blacksmoke's Avatar
Originally Posted by RAMMINVA
Could you go into detail about the APPS?
Give this a try AAPPS Reset Procedure
This procedure has shown to help 24 valve ISB engines. It is basically teaching the fly by wire accelerator on these trucks to reread the position of the pedal and it's limits. Most complaints this will help with is poor acceleration
1. Set parking brake
2. Disconnect negative battery cables on both batteries
3. Turn ignition key to run(to drain any remaining capacitors)
4. Let truck sit for 30 minutes( this is the recommended minimum)
5. Return ignition to OFF position
6. Reconnect both batteries and secure, not a timed event
7. Turn key to run position(not start) and depress accelerator pedal slowly all the way to the floor
8. Allow pedal to return to top position slowly
9. Turn ignition switch OFF
10.Release parking brake
blacksmoke
Old May 3, 2012 | 07:15 PM
RAMMINVA's Avatar
Have you done this on your 04'? I will have to give it a try, anything is worth a shot.
piesquared
Jun 10, 2009 04:07 PM
65fury
25
Apr 6, 2007 08:16 AM
Buckshotram
Jan 9, 2006 09:27 AM
G-NOTE
Sep 1, 2005 06:36 PM
C Pierce
Mar 21, 2005 08:41 AM
