pop/cracking noise front end
Old May 22, 2012 | 09:29 PM
kfredericksen's Avatar
I just bought my 05 ram a month ago and recently driving it and heard and felt in the floor boards a popping/cracking noise when accelerating and when it shifts into first if im giving it hard throttle. But it pops no matter what when I accelerate from stop if I baby it or hammer it. It has new ball joints so does anyone have any ideas it has 106kfoam on .the truck. Thanks for any help
Old May 22, 2012 | 10:10 PM
weiercd's Avatar
I would check the ujoints in both driveshaft. Don't forget to check the carrier bearing.
Old May 22, 2012 | 10:22 PM
The u joints look like the original ones because they are non grease-able and where is the carrier bearing I have moderate mechanical knowledge
Old May 23, 2012 | 09:47 AM
jhenson's Avatar
x2 on checking the u-joints.....they were far from being quality pieces!! If you have a long-bed then you will have a carrier bearing. It's bolted to a x-member under the cab where the 2-piece driveshaft goes together. If your truck is a 4x4 and you still believe the problem exists in the front end then you might consider checking the axle joints as they too are prone to fail.
Fill out your signature so we know exactly what you have.
Old May 23, 2012 | 10:34 AM
Its a 4x4 short box but it sounds like its in the middle more towards the front. It has a brand new t case but the joints other then one in the rear have a nice rust color to them and I checked today and I does not make the noise in reverse or at least I could not hear it but going forward you can hear and feel it and there is a small vibration in the steering wheel on the freeway
Old May 24, 2012 | 08:13 AM
weiercd's Avatar
Crawl under the vehicle. Grab the driveshaft and the pinion gear. Attempt to twist them opposite of one another. There should be no play. Be careful not to confuse driveline lash (movement) with the Ujoint being loose
Old May 25, 2012 | 05:50 PM
So I took it to the dealership and had them figure it out it was a bad u joint but the noise was from a loose rear motor mount they fixed it and its good as new and good thing I got an extended warranty on it so it cost me 100 bucks to fix thanks guys for all your help
Old May 25, 2012 | 06:21 PM
weiercd's Avatar
No problem glad to hear your back on the road
klx650a2
Feb 23, 2010 12:58 AM
Mlucas
Nov 29, 2009 10:44 AM
dieselJon
Nov 21, 2007 05:53 PM
973604x4
Sep 4, 2007 08:18 PM
243
Aug 12, 2004 06:57 PM
