poor idle/low power
Old Jul 21, 2011 | 06:46 PM
pw58's Avatar
poor idle/low power
I'm posting this for a friend who is on vacation,like the title says he had a sudden change in in performance.He hauled a 30 ft trailer ,winnipeg to quebec city no problem then the change.He said it also happened at easter this year but went away after dinner.I asked my buddy for codes ,as follows p2146,p2509,p0069,and po237.He just phoned me to say he cleared codes with his edge and only p2146 came back(bank 1 cyl 1-3 shorted high or low).Any idea where to look .Hoping for an easy fix ,sorry for the long post,Thanks Wayne
Old Jul 21, 2011 | 08:05 PM
BigIron70's Avatar
Cummins Guru
Usually injector or injector harness which is valve cover gastket. Check resistance of wiring to injector and injector resistance. There should be no resistance on wire and less then 1 ohm but greater then 0 ohms on injector. Could be either but I would go more toward valve cover gastket. I change several of them per week. New gastket have been changed and I haven't seen that problem anymore. Only tools needed are 10mm and 8mm socket and rachet, small screw driver to remove connector. DVOM helpful also.
kkime
Mar 25, 2010 11:05 PM
AkitaSumo
50
May 1, 2009 07:38 AM
spitzair
Jan 30, 2006 04:53 PM
Haulin_in_Dixie
Jul 17, 2003 06:17 PM
PADZZ
May 24, 2003 09:57 AM
