View Poll Results: What model truck are you experiencing the 70mph vibration?
2500 SWB
104
41.77%
2500 LWB
60
24.10%
3500 SRW LWB
17
6.83%
3500 SRW SWB
27
10.84%
3500 DRW
41
16.47%
Voters: 249. You may not vote on this poll
Poll about 70mph vibration
HEy! I just woke up this morning with my thinker ticken, and I wonder if there might be a peice of paper (like a rectangular sticker) put on a pipe or put on a cable or hose. Kinda would cause that sound like when you hold a piece of paper tight between your fingers and blow. Just a thought, when the sun comes up I'll take a look see.
That is the only thing so far that I have come up with. What would be different from when the engineers designed this and it is put on the market???? Why would the enginners need all the parts identified by stick on bar codes????
I saw this tread was running for a while, but I figured this had not been mentioned yet.
I found a part number sticker on a bar in the front. I tied a piece of wire around it, and drove it for a while, from the looks of it, all I hear now is the hum from the tires. I also checked for the weight on the power steering hose, it was there. In my book, vibration/hum problem seems to be alleviated.
The 2000 rpm or 65-70 mph vibe USED to affect my truck. Last Tuesday the dealer received the parts (shims?) that have been on national backorder. On Wednesday, after a visit with the dealer, a trip down I-40 revealed a very smooth Dodge Ram at 65-70. All other speeds up to 95 were smooth as well. The parts used to correct the vibe change the driveline angle. IIRC, they shim the carrier bearing in between the two driveshafts down.
Learjockey, I'll call the dealer tomorrow and find out. I saw the paperwork with the tsb # written on it, but I failed to get a copy. I'll post the # tomorrow evening. The dealer is at 336-996-4111 if you want to call. Ask for Randy B. in the serv. dept.
The poll does not allow for any difference between 2wd and 4wd. It may be interesting to see if there is a major differnce between the 2wd and 4wd's.
Found the text of the TSB here. Talks about low speed vibes...
http://www.alldata.com/tsb/Chrysler/index-issue.html
Let me know how it works out. I'm waiting on taking mine in until there is a better fix known.
FWIW, if you look on that alldata link you'll see another vib related TSB, something about a yoke dampener.
Dave04600
18
Aug 7, 2012 10:12 PM
