part number for cam sensor?
Old Dec 22, 2007 | 10:42 AM
j's Avatar
j
anyone have it? dodge or cummins part number? i did the search and got 10 results, none of them had the part number. i checked online and couldnt get a part number that was from dodge or cummins. anyone have a good source for these? may try cummins on monday if they're open.
Old Dec 23, 2007 | 01:45 AM
redeyedracer's Avatar
do you need a new one???have you read about the possible short located behind the AC comp and near the cam sensor plug??if ur getting a CEL for the cam sensor, this could be the problem...
Old Dec 23, 2007 | 09:32 AM
CD in NM's Avatar
I'd take a look at the cam sensor plug first as redeyedracer has suggested first. Then I'd weigh getting an aftermarket sensor over a stock one, could save you a few bucks AND then you'd have adjustable timing.
CD
Old Dec 23, 2007 | 01:16 PM
j's Avatar
j
yeah i looked at the harness. seems that it has already been covered with tape and i added split loom wiring cover to it...
whats the advantage to adjustable timing CD? doesnt my quad box do that? or am i missing something?
Old Dec 23, 2007 | 01:27 PM
CD in NM's Avatar
Hey j.
Yes, the quad box does do timing. I was thinking from a stock point of view OR if a box had a little too much timing you could smooth it out, or if you stacked boxes, again smooth the timing out. Plus, the aftermarket stuff is less expensive than the dealership stuff, and many times actually better.
CD
Old Dec 24, 2007 | 03:40 PM
j's Avatar
j
good point... i'll check some aftermarket sources. anyone know what years are the same as mine?? like 03-06 all the same or are they specific?
77machomopar
Jan 24, 2008 05:30 AM
muddin_mavric
Jul 19, 2007 10:21 PM
Gabe32
16
Feb 22, 2007 06:37 PM
ATEAV8GN
Apr 1, 2003 08:03 AM
