Pacbrake for 2005 48RE
Old Nov 16, 2007 | 05:10 PM
jsabeh's Avatar
I have a Dodge CTD and it is the 2005 with the 48RE Auto Tranny. I see that Pacbrake has an exhaust brake for this vehicle. If anyone has had this installed could you answer a few questions for me.
1. Any problems or does the transmission need upgrades?
2. Since I have the latest ECM Flash will I still need Pacbrake part C18070 Trans Lock Up Kit?
I pull at the max and would like to have the Pacbrake (C44045) installed but worry that other than requiered ECM By-pass kit I might need more transmission work to install the exhaust brake.
Thank-you-in-advance for any information you can provide me.
Old Nov 16, 2007 | 05:41 PM
Patriot2500's Avatar
I have had the PacBrake on my 04.5 2500 for almost two years and the only problem I had with it was a bad solenoid which was fixed under warranty. I did not install the brake myself, but the local shop who installed it also installed the ATS Triple Lok Commander as well. I believe this is now called the Co-Pilot. I have almost 78k on my stock brake components and can probably get a little more out of them. This has been the best mod I have done to the truck. If you tow heavy, this is a MUST HAVE.
lucey
Jan 5, 2010 02:51 PM
PZM123
Nov 3, 2009 12:50 PM
Spooler
Apr 10, 2006 08:46 PM
03CTDCO
Jan 6, 2004 09:21 PM
