Pac Brake
Pac Brake
I have a 05 with an air operated pac brake and lately I have been having trouble with it ''freezing'' on in cold weather? It works fine until I go down a grade when it is cold outside then the temp drops and makes it freeze up. If I sit at the bottom of the grade until the temp comes up it disenguages, Do you think some air line antifreeze could do the trick?
They make an air brake alcohol that is for freezing up conditions. You can get it at truck stops. Do you have a drain valve on your air tank, may be moisture causing your problem. I too would clean it real well and lubricate it. PacBrake makes/has a lubricant for their brakes. If all that does not work, you could have a bad cylinder. There is adjusting and testing procedure information in the resources information on their site. You could also give them a call, they are very helpful and have good customer service.
CD
CD
The silver solenoid on there has a rubber seal and spring in the middle if you unscrew the two halves apart. It might need a good cleaning. I had to do that to mine. Lubing the cylinder arm is a good thing to do. Don't use WD-40 as it will dry the seal out. Pac Brake has a good lube to use like said above.
Yah, Pac Brake is right near me, I'll hafta get some of that stuff one day before I start having problems.
They put out a good kit, you'd think they'd include the lube too?
Might look at the air bags while I'm there.
I installed a drain on my tank when I put the system in. I just used a 175 psi blow off valve for a compressor. Got it at Tractor supply. This way every so often I can just pull the stem (spring loaded) and clear the bottom of the tank. You'd be surprised how nasty it gets in there, very rusty water from the cheesy tank.
Shilohman
22
Nov 19, 2009 05:13 PM
iflych52
25
Oct 10, 2006 09:25 PM
wvcowhauler
13
Apr 3, 2005 11:39 PM
