P2769 code today
Old Aug 2, 2007 | 03:18 PM
belgianmagic's Avatar
P2769 code today
whats up with this ?? Anyone? could it be from T/C lockup switch...haven't had this code before
Old Aug 3, 2007 | 12:27 AM
NO IDEAS HERE??thanks
Old Aug 3, 2007 | 08:07 AM
jrussell's Avatar
That code is related to TC voltages. Did you use a 33ohm resistor when you installed the lockup switch? Have you stalled the truck with the TC locked up?
Old Aug 3, 2007 | 08:24 AM
1) no
2) no (almost though)
Old Aug 3, 2007 | 08:52 AM
jrussell's Avatar
I think either one (or both) of those will throw that code. I know if you let the truck stall (or maybe come close?) it will throw that code. Not positive on the resistor, but I've heard that can cause it also.
I would add a resistor and clear the code with your Smarty. It shouldn't come back unless the truck stalls with the TC locked.
Old Aug 3, 2007 | 09:15 AM
ok thanks I'll try it(resistor) ...Ive had the switch for weeks and use it every night ( I travel 22 miles @35-42mph ,to lock for better mpg) and haven't gotten this before now though
Old Aug 4, 2007 | 08:04 AM
UPDATE... Drove to and from work with SMARTY on 3 and ,NOT IN "TOW MODE" and did NOT use the lock switch
Drove to work 'like a little old lady'....NO CODES
Drove home ...Normal (no tow or lock) mashed on her a FEW times...NO CODES
so I will see if I cant find a 33... all I can find is 22's (2 tandom?)
Old Aug 4, 2007 | 03:09 PM
chucktuna's Avatar
Ive got the switch and the resistor and my light comes on ( with the same code as yours if I remember) about every few months or so....I've also stalled it with the switch a few times but it doesn't seem to relate to when the light comes on...
I just reset it w/Smarty and am on my way.
Wonder if my resistor is "burnt out" or something, cause it seems to happen more now than when I first installed it,
chuck
Old May 17, 2008 | 02:12 PM
forgot to update
Installed resister in ground side ...NO MORE CODES
PowerstrokeRacer
0
Dec 23, 2008 08:50 PM
Pearce
Aug 18, 2005 05:12 PM
lightening ram
Jan 4, 2005 10:48 PM
RHC
Feb 25, 2003 08:27 PM
