P2269
Old Apr 15, 2006 | 08:18 AM
sawboywv1's Avatar
P2269
No water in fuel light came on.... however when I cycle key I get P2269. P2269 is "water in fuel condition" what does this mean???
Old Apr 15, 2006 | 02:11 PM
XZILR8N's Avatar
I would err on being cautious and would intrepret that literally as "water in fuel" even if the WIF light is not illuminated. Perhaps the indicator light circuit could somehow be defective and the sensor is working properly and tripping the code.
I would drain all the fuel out of the fuel filter drain (yellow handle) into a clear bottle and see if any water comes out. You might even pull the fuel filter out and clean the WIF contacts in the bottom of fuel canister area.
I would put in a fuel additive that either emusifies or demulsifies (your choice) water in diesel for good measure.
If you still get the code, I would call the Dealer Service dept. and ask them what you should do. They may say not to drive it and will want to tow it in just to be safe.
Old Apr 15, 2006 | 02:13 PM
68ss's Avatar
DRIVEABILITY - DIESEL
Symptom List:
P2269-WATER IN FUEL (WIF)
When Monitored and Set Condition:
P2266-WATER IN FUEL (WIF) SENSOR VOLTAGE TOO LOW
When Monitored: Ignition on.
Set Condition: Low voltage detected at the WIF signal circuit at the ECM.
POSSIBLE CAUSES
WATER IN FUEL SENSOR SIGNAL CIRCUIT SHORT TO GROUND
ECM
TEST ACTION APPLICABILITY
1 Drain the Water in fuel separator.
With the DRBIIIt, erase DTCs.
Cycle the ignition switch from on to off to on.
With the DRBIIIt, read DTCs.
Did the DTC P2269 return?
ENGINE- 5.9L
CUMMINS 24V
DIESEL
Yes ! Refer to symptom P0178-WATER IN FUEL SENSOR VOLTAGE
TOO LOW in the DRIVEABILITY category.
No ! Go To 2
2 Disconnect the Water In Fuel Sensor harness connector.
Monitor the DRBIIIt while jumping the signal circuit of theWater in Fuel sensor and
Battery (+).
Did the Water In Fuel Light go out?
ENGINE- 5.9L
CUMMINS 24V
DIESEL
Yes ! Test Complete.
No ! Replace the ECM.
Old Apr 17, 2006 | 06:24 AM
sawboywv1's Avatar
"Water in fuel light" never came on!
napa169
May 3, 2014 06:40 PM
