P2121 And P2122 Engine Goes To Idle
Old Nov 11, 2009 | 09:38 PM
reddog2003's Avatar
I have just got the code P2121 and P2122 and my engine goes back to idle as I am driving. After a few seconds and some playing with the pedal( pushing it to the floor and cussing) it starts working again. Can anyone tell me if it is the APPS, I hate to spend $500.00 on it and find out its not the problem. I am not sure how I could even test it since it is so random. Please help!
Old Nov 11, 2009 | 09:49 PM
hector's Avatar
I don't know what APPS is.. P2121 Code is throttle/pedal position sensor/switch D circuit range/performance
P2122 says the same except low circuit
Old Nov 11, 2009 | 10:52 PM
annabelle's Avatar
It was on mine.........if you need an apps buy a modded one from Timbo 01 for less than $200.00. Will install in 30 min.s tops. He is a great guy to deal with. "timbom1976@aol.com"
Old Nov 12, 2009 | 08:17 AM
Grit Dog's Avatar
99% chance it's the APPS. To verify, pull the plug from it, clean the contacts and then reset the APPS voltage. Bad connection may throw the same codes. If this doesn't work, then it's the APPS. Not too hard to replace and there's several discussions with directions on the site here.
ziggy
Jun 24, 2013 05:57 PM
Raspy
0
Nov 26, 2012 06:07 PM
spinlocker
Apr 10, 2010 01:13 PM
Grey Goose
Dec 29, 2009 12:58 PM
Bill Hall
Sep 21, 2007 06:35 PM
