p0514 code
Old Feb 17, 2011 | 04:20 PM
lane22's Avatar
p0514 code
what will cause this code and the fix.note truck stock 2003 2500 .stock batterys
Old Feb 18, 2011 | 02:54 PM
booman70's Avatar
p0514 battery temp sensor rationality. Ignore it will go away. It is a sensor under the drivers side battery and when it is cold the computer measures temps on all the sensors and if there is to much difference the truck trips this code. The fix was to reflash the computer to allow a greater difference between the temp sensors but you will get the reverse horn honk if you get reflashed I just ignore mine it goes away after a few days.
ccw55
Feb 7, 2006 04:50 PM
doorguy
Jan 26, 2006 05:05 AM
BAJA MAN
Dec 10, 2005 06:17 PM
billyrae
Nov 19, 2004 06:00 AM
