P0237 & Now Truck very Hard to Start
Old Dec 16, 2005 | 06:12 PM
mstocktill's Avatar
Angry P0237 & Now Truck very Hard to Start
I really need your help guys. Last week, right after the first real snow of the year here, my truck starting having problems starting in the morning. I would have to let the grid heater cycle three or four times , pump the accellerator while cranking, and then the truck would start. The truck would run, no fast idle at all, no stalling...; but it would run very rich until it warmed up. The temps have risen lately, and the truck is still hard to start always now; unless it has only been a few hours since the last run in the truck. The truck's fuel mileag has also dropped to 8 - 10mpg city and highway. Any help is appreciated.
Mark S.
Old Dec 16, 2005 | 06:21 PM
Bad Ramer Jamer's Avatar
Sorry I can't help much as I'm new to diesel's myself. But incase you don't have this all ready, here it is.
http://www.obdii.com/codes.asp
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old Dec 16, 2005 | 07:08 PM
handymantim's Avatar
Check the clamps on all your intake hoses. I'm wondering if you have a boost leak.
Old Dec 19, 2005 | 08:32 PM
mstocktill's Avatar
Exclamation
I finally checked all connections to everything from evrywhere to everything....no loose clamps anywhere. Thanks for the suggestion anyway.
Mark S.
Old Dec 20, 2005 | 09:06 AM
bigblock2stroke's Avatar
Mark S.
You probably either have some sort of wiring problem (loose or bent pin in connectors) or the boost pressure sensor is bad.
That fault is actually for an open circuit. Not just low boost (even though that's what it says).
I've seen lots of boost leaks with no fault codes. Most of the time you can hear it (like letting the air out slowly in a balloon, very high pitched).
Does the truck have good power. If you have no boost, it will be a total slug. If you have power and its not making the balloon noise, its probably an electrical problem. The check engine light might even go off after awhile if the fault went inactive.
Old Dec 20, 2005 | 12:08 PM
DDahl's Avatar
Check your grid heater relay wiring (next to battery). Three of the four nuts attaching the relay wires were loose on my 05. Check all the connections! Also, there is a fusable link from the battery to each grid heater relay. If either or both have blown you will have no grid heating --- really bad starting.
Old Dec 20, 2005 | 09:40 PM
mstocktill's Avatar
I have great power, so no problem there. Y=The check engine light has gone off and has not returned. I should get home early enough tomorow to check the wiring and fusable links for looseness or breaks. Thanks for the info.
Mark S.
mcoleman
Jun 13, 2009 10:14 PM
Thedieselkid
Dec 19, 2007 03:01 PM
allmountainbike
Sep 11, 2007 09:11 PM
Bobcat698
Dec 3, 2006 07:57 PM
97Dually
May 18, 2006 10:47 AM
