p0192
Old Mar 31, 2009 | 05:43 PM
450r's Avatar
p0192
my truck threw a p0192 code today meaning fuel press sensor low voltage. it did it right as i started it up and it idles kinda rough and slow but is pretty loud . what could this be any help
Old Mar 31, 2009 | 09:01 PM
BigIron70's Avatar
Cummins Guru
Ignition on, engine not running.
Measure the voltage between the 5-volt supply and return circuits of the Fuel pressure sensor harness connector.
Is the voltage between 4.5 and 5.5 volts? Yes
Reconnect the disconnected Fuel Pressure Sensor harness connector.
Clear the code
While monitoring scan tool, disconnect the Fuel Pressure sensor harness connector.
Does the DTC P0193 set? Yes
Replace the fuel pressure sensor
Old Feb 8, 2011 | 02:41 PM
jmlcolorado's Avatar
Clear the code
Where is this connector located?
Dieselhed
Dec 29, 2007 07:11 PM
CTDinMT
Jun 21, 2007 12:21 PM
H8GAS
22
Feb 15, 2007 09:40 AM
coobie
Oct 17, 2005 10:53 AM
schorb
Oct 9, 2005 10:59 AM
