p0088
Old May 26, 2013 | 07:48 PM
DragonSlayer's Avatar
Unhappy p0088
Got the **** code........pulled and replaced the fuel filter today, no signs of algae. I'm going to buy a FCA when the stores open. I hope that fixes the cel.
Old May 28, 2013 | 09:31 PM
Pumped out the bad fuel from tank to replace with fuel from another location. While priming the fresh fuel in, I cranked and got aanother code. The truck ran for maybe 30 seconds and died and would not start. New code is p0628. Lift pump low voltage. I can jump the pins in the fuse box and make the pump run, but it will not run with relay installed. Any ideas?
Old May 29, 2013 | 04:44 PM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
Did you swap out the "bad" relay for a "good" one and see if that's the issue?
Old May 29, 2013 | 06:49 PM
Yes sir, we did the relay shuffle! I think my pump died while I was pumping the ful out with it. I have no way of knowing if thats the orig pump or not.
wild4stangs
Jun 18, 2007 11:19 AM
d_emory
Mar 28, 2006 10:49 PM
TE-44
Nov 1, 2005 10:20 AM
HaulinBut
Dec 8, 2004 10:21 AM
