p0069
p0069
Map baro correlation, where do our trucks read barometric pressure. I keep getting this code and can't figure out whats wrong, checked connections and checked and covered wire at the ac pressure switch. Just run out of ideas other than a bad sensor.
btw truck goes into "limp mode" at times when cel comes on. It will not build over 21 lbs. boost but rail pressure is always normal.
thanks in advance
thanks in advance
ggades
13
Apr 17, 2004 12:56 PM
