p 0251 and p0148
Old Oct 24, 2010 | 06:19 PM
mckimar's Avatar
p 0251 and p0148
my brothers truck is pulling these two codes P0251 CP3 Pump Regulator Control. but what needs to be replaced or adjusted??
just put a raptor 150 lift pump on it and not sure if that is it or what??
the second code is P0148 High Pressure Common Rail (HPCR) Fueling Error Checksum is this caused because of the p 0251??
need help thanks
04.5 5.9 3500.
Old Oct 24, 2010 | 08:38 PM
BigIron70's Avatar
Cummins Guru
Does the rail fuel pressure fluctuate more then 500PSI when at idle? If yes then replace the fuel control actuator (FCA).
Part No. 05183245AA Actuator
Old Oct 24, 2010 | 09:23 PM
Spooler's Avatar
Yeap, sounds like a bad FCA.
Old Oct 28, 2010 | 11:55 AM
mckimar's Avatar
today i was driving and the truck lost all power and started blowing black smoke and shut off but started up again what would that be?
Old Oct 28, 2010 | 08:43 PM
JJPage's Avatar
I agree with the FCA....but also could be the cascade valve on the CP3, if the Raptor 150 is pushing too much pressure to the CP3 injection pump, the cascade valve will open, bypassing fuel to protect the CP3.
You need to check the pressure from the Raptor to the CP3, should be around 20 lbs.
wap
Aug 25, 2008 05:45 PM
wap
Oct 16, 2005 05:18 PM
wyomingsmoke
Aug 4, 2005 12:47 AM
