Overheating at low speeds and P0480 code
Old Mar 13, 2011 | 05:30 PM
efil4ynot's Avatar
When at low speeds and doing some work (pushing through snow drifts, maneuvering trailer in the yard, pulling out tree stumps, etc.) my truck starts to overheat pretty quickly. I also pulled up the P0480 code w/ my Smarty (Cooling fan 1 control circuit).
So, I did the trick where you cover up the condenser and turn on the AC and the fan does its job just fine. This being said, does anyone have any ideas as to what would be making this happen? Is there another way to check the fan clutch? I have an ohm meter, if that helps.
Thanks in advance.
Old Mar 15, 2011 | 07:35 PM
efil4ynot's Avatar
Anyone have any ideas?
Old Mar 15, 2011 | 08:39 PM
Purplezr2's Avatar
Is your radiator clogged with mud or dirt?
Old Mar 15, 2011 | 10:35 PM
efil4ynot's Avatar
Nope, I checked. Also, this began a few months ago all of a sudden.
Old Aug 6, 2014 | 11:12 PM
roughstock's Avatar
Ever figure it out? mine is doing similar now. even worse after I changed out the fan clutch
Old Aug 7, 2014 | 04:23 PM
efil4ynot's Avatar
Sorry but no. I ended up having the cooling system flushed and replaced the fan clutch (wasn't necessary). I haven't had it overheat since however, my temp gauge will jump up to 200 degrees pretty quick, causing the fan clutch to lock up. Before this issue my coolant temp was always at 191 +/- 2 degrees. Good luck.
Old Aug 9, 2014 | 10:28 PM
roughstock's Avatar
my NEW fan clutch wont engage at all. So if im in town in traffic, I over heat, highway is ok. Going to test old fan VS new one.
Old Aug 11, 2014 | 11:06 AM
efil4ynot's Avatar
You may want to check the wiring that runs between the fan shroud and the radiator, near the bottom. I'm pretty sure that there was an issue with a wire rubbing through and grounding out but it may have just been the early 3rd gens. I would also make sure that the relay is functioning properly.
Old Aug 13, 2014 | 10:04 AM
roughstock's Avatar
OHHHH. Forgot about the relay. Thanks. ill look at that next.
Wiring looks fine. Made sure I correctly routed the new wires. seen them get wrapped up in the fan before. Changed out a lot of these 3rd gen fan clutches.
Old Aug 27, 2014 | 03:56 PM
efil4ynot's Avatar
Did you ever get it figured out?
Old Aug 27, 2014 | 10:47 PM
roughstock's Avatar
not yet. been driving the jeep. currently rebuilding the front end on the dodge. I did inspect the wires and there appears to be some damage to them. Ill look further when time allows.
Old Aug 28, 2014 | 02:15 PM
bishgeo's Avatar
I would go ahead and replace thermostat from genos then make sure all the air gets burped out. I don't think fan is supposed to engage with out ac until 210-215.
roughstock
Aug 7, 2014 09:50 AM
gabbyfan
Aug 22, 2009 06:57 AM
043500QC
Aug 28, 2007 03:12 PM
Jnoble
Jan 10, 2006 03:38 PM
SuperGewl
0
Apr 22, 2005 09:10 PM
