Overfilling the NV5600
Old Oct 4, 2006 | 07:13 PM
nickleinonen's Avatar
anyone know off hand what the stock fill plug thread type is? from what i remember, the plug isn't a npt fitting. maybe bspt?
i'm thinking of a street elbow in the fill location.. would get that fill port to the same height as the top pto hole i think...
Old Oct 5, 2006 | 12:20 PM
MikeyB's Avatar
I don't know the answer to that one.
I have a 1 gallon gear lube container with a hand pump on top. The tip on the hose is small enough to fit inside the PTO cover bolt hole.
MikeyB
Old Oct 6, 2006 | 07:49 PM
when i next service my trans, i will top it up from the top pto cover bolt hole.. [got a brand new 1pt drip can waiting for that...]
Old Oct 6, 2006 | 08:38 PM
coontz0473's Avatar
sorry!!
Originally Posted by MikeyB
After the recommendations with the hotshot runners I added more fluid to the NV5600. Went from 5 qts to 6 qts now. I cannot believe the difference the one extra quart did to the transmission. Shifts are reeeeaaaaally smooth now and low rpm gear rattle is pretty much gone. Mikey likey.....
MikeyB
Sorry Mikey, don't mean to highjack your thread....but......I have never changed my tranny fluid yet....40k on the ticker......I was wondering if you or anyone could give me some pointers????? plan on tackling this job this weekend....what fluid, how much and where did you buy...any other help or comments you guys could throw my way would be a great help....thanks
Old Oct 6, 2006 | 09:05 PM
C Schomer's Avatar
Get 6 qts of DC 4874464(I think), Royal Purple Synchromax, Amsoil MTF or similar. 5 qts of MTF (my first change) was $48 to my door. Pull the driver side PTO cover to drain and mop out all the oil. Reach in and get the flat magnet off the bottom and clean it. I drilled and tapped a drain hole and a place for a temp probe. My oddball fill plug is going to get drilled out and have a brass ell silver solder to it next. Craig
Old Oct 6, 2006 | 09:27 PM
coontz0473's Avatar
thanks craig, why 5 qts of MTF and 6 qts of Royal Purple?? where did you get the royal purple? online i assume? thanks again will check it out.
greg
Old Oct 7, 2006 | 07:07 AM
MikeyB's Avatar
I think what Craig did was at first used 5 qts and then later on added the 6th to the tranny.
So your choices are for fluids is Pennzoil Synchromesh Fluid, Redline MTL, Amsoil MTF or the factory lube from the dealer. You can get away with using Royal Purple Synchromax if not towing heavy. RP is a little light in the vicosity range compared to the other fluids.
MikeyB
Old Oct 7, 2006 | 11:06 AM
C Schomer's Avatar
I did a 4.5 qt change with MTF this summer. Two weeks later, I finally got DC to warranty the reverse synchro problem and they filled with DC stuff. Then I added another qt of DC stuff, last weekend. I didn't know that about RP - I'll take them off my list. RP Max Gear 75w90 was too thick for my NV4500 so I was hoping their Synchromax would be on the thicker side, as well. I get RP at NAPA - 27th & Thomas - I use there MAX Gear in my diff - great stuff. My Schaeffer rep says he has something that works in the 5600 but it's not exactly recommended by Schaeffer. I might look into it more and see what it is. I'd like to find something a little thicker for the Az. climate. Craig
Old Oct 19, 2006 | 01:31 PM
SupaDupa's Avatar
I just drained the extra out of my tranny today. Seems it was leaking..... out the front seal maybe???? Anyhow it didn't do this prior to the overfill, so I figured I'd do the easy thing first by draining some out. Level parked her and drained out until she stopped coming out the fill hole. I thought at first it was oil from the blow by hose, but this fluid was very clear, like the Amsoil in the tranny. My engine oil is black normally. Didn't smell like motor oil either. There is a space about 1/4-5/16" wide by about 5-6" long on the front side of the tranny where the oil/lube looks like it is coming from. Any input is appreciated!!! Thanks.
Old Oct 19, 2006 | 02:59 PM
MikeyB's Avatar
Supa,
How much did you put in originally?
I'm at 6 qts and haven't seen any evidence of leaking, yet.
MikeyB
Old Oct 19, 2006 | 07:21 PM
SupaDupa's Avatar
I originally bought 5 quarts of Amsoil MTF because the specs say the NV5600 holds 4.75 quarts. Well I drained the old out from the bottom PTO bolt. I didn't pull the cover. With the truck level, I could only squeeze in almost 4 quarts of Amsoil before the fluid was running out the fill hole.
Then I read this thread and I removed the top PTO bolt and put probably 2/3-3/4qt more Amsoil before it was running out the top bolt hole.
So my SWAG would say that I had at least just over 4.5qt. of Amsoil in there plus whatever remained in there by me not removing the PTO cover prior to me draining the "extra" this AM.
How much fluid remains in the tranny if you don't pull the PTO cover????
Old Oct 19, 2006 | 08:19 PM
not that much... i pulled my cover and mopped out the extra in the bottom with some rags.. i'll guestimate less than a pint
Old Oct 19, 2006 | 08:30 PM
MikeyB's Avatar
Shouldn't be much fluid left in the transmission when drained from the lower PTO cover bolt hole. That's the lowest point on the transmission.
I had to jackup the back of the truck to get 4.5qts into the tranny using the fill plug. I got the other 1.5qts in through the top PTO cover bolt hole.
That front seal shouldn't be leaking with only 4.5qts.
MikeyB
Old Oct 19, 2006 | 08:33 PM
SupaDupa's Avatar
Thanks for the replies!!! I'll let you all know if this stops the leak. I hope it does. I really didn't notice a change in the way it shifted or sounded; I just figured that I'd try it out!!!
Old Oct 19, 2006 | 09:24 PM
Mixer Man's Avatar
Originally Posted by cmnspwr
I overfilled mine by removing the console in the floor, after which I then took out the shift tower. You can see right down in the tranny. There is absolutely no spillage this way.
That's the way I do it a whole lot easier too !!!! Thanks for info Mikey I am going to try that tomorrow just keep us informed . Don't want to blow a seal and deal with that fiasco .
