O'Reilly / Checker ATF +4
Old Sep 15, 2010 | 12:15 PM
pdogg's Avatar
Stopped by my local Checker Auto last night and noticed they are now carrying O'Reilly branded oils, specifically ATF+4 transmission oil....
a buck cheaper per quart than the valvoline too.. (~$4.50 ea)
states on the label meets Chrysler specs..
Anyone have opinions on this?
Old Sep 15, 2010 | 07:06 PM
TexasCTD's Avatar
If it meets ATF +4 specs I don't see why it wouldn't work fine.
Old Sep 18, 2010 | 12:06 PM
BroncoAZ's Avatar
Mopar ATF+4 can be had at Wal Mart for less than $5 per quart.
Old Sep 18, 2010 | 03:25 PM
annabelle's Avatar
They don't carry it at mine anymore.
Old Sep 18, 2010 | 03:36 PM
BroncoAZ's Avatar
I've found recently that some stores in affluent areas do not stock 15W-40 motor oil or oil filters for diesels. I'm sure it's a function of volume, but it sure sucks.
Fortunately my ghetto wal mart at Tatum and Bell still has ammo and stuff for diesels.
Old Sep 18, 2010 | 04:23 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
My transmission guy says to stick with Mopar ATF+4. He's not a fan of the Valvoline or other off brands of ATF+4. He has seen and has even demostrated to me how the Mopar seems to stick better to gears and bearings.
Old Sep 18, 2010 | 09:33 PM
Shagginwagon's Avatar
Are you using ATF+4? The Kondolays told me to run only mercon/dex III in my DTT.
Old Sep 18, 2010 | 09:50 PM
JPR Ram's Avatar
Really????? I don't know about that. Mercon/Dexron III is NOT a synthetic blend. 47re's and 48re's require that synthetic blend for the seals and bearings. To each your your own I guess........
I mean don't get me wrong, I do use Mercon/Dexron III............................................... ....... In my transfercase..................
Old Sep 18, 2010 | 10:21 PM
annabelle's Avatar
Same as I was told I should use in a modded tranny. but not a stock tranny.
Old Sep 20, 2010 | 06:53 PM
TexasCTD's Avatar
Yep, i've always run only Mopar ATF+4....before and after having it built. 139K on it now....shifts great. It was built at 88K by an authorized DTT builder. He put ATF +4 in it.
Old Sep 21, 2010 | 07:03 AM
05HDRAM's Avatar
My local Wally world did not have any Mopar in stock when I changed my fluid 15K ago. I ended up using Pennzoil ATF + 4 and everything is running fine. Shift & Temps running the same as the Mopar fluid it replaced. Like Texas said, the fluid must meet the requirements to be labeled ATF + 4, so I am not overly concerned. I have not seen threads on transmissions going out due to non Mopar ATF use.
blake2500
15
Nov 22, 2007 05:34 PM
rbuchana
20
Sep 3, 2006 12:46 PM
Huey
Feb 20, 2003 08:36 PM
