One piece shaft
#52105655AD is listed for 03-04 diesel HD 6 SPD manual (DEE) 4x4 QC/LB trucks
Drive shaft, Ram 2500; 1 Piece Driveshaft; 4WD; 5.9L Diesel; Manual Trans; 6 Speed for 2003 Dodge Ram 2500 52105655AD Securely order today - it's quick and easy.
6 speed 2wd there is not one and you can't get anyone to make one for you.
Joe
Joe
Joe
Joe
Excellent link and info...
However, for a 2003-05 QC Shortbox 2wd with the NV5600 6 speed manual trans, you can get a custom 1 piece aluminum drive shaft built.
I don't have one but have researched it. The 1 piece driveshaft ends up being about 3 inches longer than a QCLB 4x4 drive shaft.
This still ends up shorter than the max length published by several drivetrain companies.
I have never had an issue with my 2 piece driveshaft but this will be my solution when I do.
The 2wd G56 trans is identical to the 4x4 G56.
There is no slip joint in the trans output shaft unlike the 2wd NV5600.
Therefore there is no way to run a 1 piece driveshaft on a 2wd G56.
Joe
Joe
Driveshaft Specialist Inc
kertoncol
May 5, 2010 10:04 AM
RWDCelicadude
14
Jan 14, 2010 11:17 AM
CCOUGHRAN
Jan 4, 2005 10:10 PM
